FME Flow: 2026.2
Determining FME Flow Processes
To determine the FME Flow processes that are running:
- Windows: Launch the Windows Task Manager. Ensure that the Task Manager is set to show processes from all users.
- Linux: Examine the output of:
ps -A | grep -i fme ‘fme\|postgres\|redis'
The following FME Flow processes might be listed:
| Windows | Linux | Description |
| FMECleanup.exe | FMECleanup | FME Flow System Cleanup service |
| FMEConfiguration.exe | FMEConfiguration | FME Flow Backup & Restore |
| FMEConnection.exe | FMEConnection | FME Flow Database Connections and Web Connections access |
| FMEEngine.exe | fme | One for each running FME Engine |
| FMEMountPoint.exe | FMEMountPoint | FME Flow Resources |
| FMENotifier.exe | FMENotifier | FME Flow Subscriber Manager - requires the FME Flow Core to be running |
| FMEProcessMonitorCore.exe | FMEProcessMonitorCore | FME Flow Process Monitor for Core processes |
| FMEProcessMonitorEngines.exe | FMEProcessMonitorEngines | FME Flow Process Monitor for Engine processes |
| FMEPublisher.exe | FMEPublisher | FME Flow Publisher (includes Automations Triggers) |
| FMERelayer.exe | FMERelayer | FME Flow Publisher Manager |
| FMEScheduler.exe | FMEScheduler | FME Flow Schedules service - requires the FME Flow Core to be running |
| FMEFlow.exe | FMEFlow | FME Flow Core |
| FMEFlow_ApplicationServer.exe | java | The Apache Tomcat Web Application Server (servlet) that is installed with an Express installation of FME Flow, or as an option with a Distributed installation of FME Flow. |
| FMESMTPRelay.exe | FMESMTPRelay | FME Flow SMTP email receiver. For more information, see Configuring FME Flow to Receive Email. |
| FMESubscriber.exe | FMESubscriber | FME Flow Subscriber (includes Automations External Actions) - requires the FME Flow Core to be running |
| FMEWebSocket.exe | FMEWebSocket | FME Flow WebSocket Server. |
| postgres.exe | postgres | The PostgreSQL server for the FME Flow Database that may be included with an installation of FME Flow, depending on deployment architecture. |
| memurai.exe | redis-server | FME Flow Queue, for managing Queue Control. |
| FMEUtilityEngine.exe | fmeutility | For internal processes only. |
