FME Transformers: 2026.1
Categories
Calculated Values
Strings
StringLengthCalculator
Calculates the length of strings and the number of bytes in a blob.
Example
To calculate the number of bytes in a blob:
  1. Add a raster format reader (for example, TIFF).
  2. Connect a RasterExtractor followed by a StringLengthCalculator.
  3. In the StringLengthCalculator parameters, select _rasterBlob as the Source Attribute.
  4. Connect an Inspector transformer.
  5. Run the workspace.
Locate the _length attribute name in the Information Window:
  • Note that in non-ASCII character sets, the length is the number of actual characters (some or all of which could be multi-byte) in the string, which may not match the number of bytes used to store the string.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the StringLengthCalculator on the FME Community.
