FME Transformers: 2026.1
Categories
Integrations
Web
Web
Workflows
Related Transformers
AzureBlobStorageConnector
AzureFileStorageConnector
BoxConnector
CesiumIonConnector
DropboxConnector
GoogleCloudStorageConnector
GoogleDriveConnector
HDFSConnector
ProjectWiseWSGConnector
S3Connector
OneDriveConnector
Connects to Microsoft OneDrive to manage files and folders.
Jump to Configuration
  • Managing datasets on Microsoft OneDrive by uploading, downloading, and deleting files and folders
  • Transferring file contents into or out of an attribute in FME
  • Retrieving file and folder names, paths, links and other information from Microsoft OneDrive to use elsewhere in a workspace
The OneDriveConnector uses your Microsoft OneDrive account credentials to perform various management tasks:
Action
Task
Delete
Delete files and folders.
Download
Download a file or folder to an attribute, file, or folder.
List
List the item details for the contents of a folder.
Upload
Upload a file, folder, or the contents of an attribute.
Once valid account credentials have been provided, you may browse to available content for the selected Action.
This connector is compatible with OneDrive personal and OneDrive for Business accounts.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
  • Run Once: When no input features are connected, the transformer runs one time and outputs as many new features as the Action returns.
  • This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
  • The FeatureReader can access Microsoft OneDrive directly but does not download a local copy of the dataset.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Microsoft OneDrive account
Aliases
History Released FME 2017.0
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the OneDriveConnector on the FME Community.
