Google BigQuery Writer Parameters
Service Connection
Credential Source
For Google Cloud authentication information, see Getting Started with Authentication.
Web Connection – Uses Google Cloud BigQuery API via OAuth 2.0 to authenticate and make requests.
Application Default Credentials – Automatically authenticate access based on the system environment. This will attempt, in order, to resolve credentials using the following sources:
The credential file pointed to by the environment variable `GOOGLE_APPLICATION_CREDENTIALS`
The credential file created by using the Google Cloud CLI.
The metadata server on a Google Cloud Engine Virtual Machine instance.
About Web Connections |
Connections store authentication information. For general information about web connections, please see Using Web Connections. For information about managing web services (including authorization credentials such as Client Id and Client Secret), please see Managing Web Services. Connection From the Connection parameter in a web service format, you can do one of the following:
Account
When Credential Source is Web Connection, select web connection account for authentication.
Project
Select the Google BigQuery project.
If Credential Source is Application Default Credentials, leaving this parameter empty will use the project associated with the retrieved credentials.
Write Options
Table Handling
- Write if Empty (default) – Load features to table only if the table is empty, or does not exist.
- Append – Load features on a pre-existing table.
- Overwrite – Overwrite the entire table with only the new features. All pre-existing data will be overwritten.
Dataset
The dataset to load features into. This dataset must exist before writing to it.
Number of errors allowed
The number of features allowed to produce errors and be ignored. These features will be skipped and not loaded onto Google BigQuery.
Value: Must be greater than 0.
Table Splitting
The number of features to write at a time to BigQuery.
The default is 0, in which features are written at the end of translation.
Spatial
Coordinate systems may be extracted from input feature data sources, may come predefined with FME, or may be user-defined. FME allows different output and input coordinate systems, and performs the required coordinate conversions when necessary. To perform this reprojection, FME uses the CS-MAP reprojection engine, which includes definitions for thousands of coordinate systems, with a large variety of projections, datums, ellipsoids, and units.
For systems that know their coordinate system, this field will display Read from Source and FME will read the coordinate system from the source dataset. For most other input sources, the field will display Unknown (which simply means that FME will use default values). In most cases, the default value is all you'll need to perform the translation.
You can always choose to override the defaults and choose a new coordinate system. Select More Coordinate Systems from the drop-down menu to open the Coordinate System Gallery.
- The coordinate systems file coordsys.db in the FME installation folder contains the names and descriptions of all predefined coordinate systems.
- Some users may wish to use coordinate systems that do not ship with FME, and in those cases, FME also supports custom coordinate systems.
- Working with Coordinate Systems in FME.
- None – Google BigQuery will infer and assign data types to columns based on the incoming data
- Geography – A spatial column will be generated from the geometries attached to the loaded features and interpreted in WKT. The column will data type will be set to GEOGRAPHY on Google BigQuery.
When Spatial Type is set to Geography, specify the name of the column that will hold GEOGRAPHY type data.
Advanced
This setting enables the creation of tables without data features.
- No – Tables are only created when receiving data features.
- Yes – Tables are created without data features if possible.
