Industry Foundation Classes (IFC) Reader/Writer
FME reads and writes files in the Industry Foundation Classes (IFC) format.
The IFC_API reader produces FME features from IFC elements, with feature types based on the IFC element category.
The IFC_API writer only accepts features that have the ifc_element_type attribute and creates a validated IFC file in the IFC4 or IFC4x3 schema versions.
Supported Schemas
The reader can read IFC files with the following set of schemas:
- IFC2x_FINALcs
- IFC2x2_FINAL
- IFC2x3
- IFC4
- IFC4x1
- IFC4x2
- IFC4x3
- IFC4x3_RC1
- IFC4x4
The writer can write IFC files with the following set of schemas:
- IFC4
- IFC4X3_ADD2
Industry Foundation Classes (IFC) Product and System Requirements
Format |
Product |
Operating System |
Reader/Writer |
FME Form |
FME Flow |
FME Flow Hosted |
Windows 64-bit |
Linux |
Mac |
Reader |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Writer |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Reader Overview
The IFC reader will automatically detect the version of the IFC file it is reading, by analyzing the file header.
The reader supports all IFC versions.
The value for the reader dataset is the path to the .ifc source data file. If the data file does not exist, or if the file is unrecognized by the reader, then the translation will fail.
IFC 3D element geometry will be represented as 3D surfaces and solids on features.
Writer Overview
The IFC writer will create and validate an IFC4 or IFC4x3 file based on the selection in the writer parameters. To ensure that the output file is valid, the writer will create a few Ifc elements by default if there is no feature for them in the input. These are IfcProject, IfcSite, IfcOwnerHistory, and their required attributes.
The value for the writer dataset is the path to the .ifc destination data file. If the data file already exists, it will be overwritten.
