FME Form: 2026.1 BETA
Menu, Toolbar, and Shortcuts
File
Command Keyboard Shortcut Function
Open Dataset
Ctrl O
Opens a file browser so you can pick a dataset.
Open Recent   Displays a list of the most recently viewed files.
Add Dataset
Ctrl D
Opens a file browser so you can add a dataset to the current view.
Save Data As
Ctrl S
Saves the current view to a separate dataset. See Saving Data.
Save Selected Data As
Ctrl Alt S
Saves selected features to a separate dataset. See Saving Data.
Close Display
Ctrl F4
Closes the current view.
Exit FME Data Inspector Ctrl Q Shuts down the FME Data Inspector.
View
Switch to Layout   Switches the focus of the tabs in the main window to the specified layout if more than one is open.
Restore FME Default Layout
Restores the window layout to the FME default.
Display Control Ctrl Shift d Opens or closes the Display Control.
Record Information Ctrl Shift f Opens or closes the Record Information window.
Log Ctrl Shift l Opens or closes the Log window.
Table View Ctrl Shift a Opens or closes the table view.
Start Tab   If checked, shows the start tab.
Status Bar
If checked, shows the status bar.
Toolbar   If checked, shows the toolbar.
Save Layout As   Allows you to save the current window layout.
Delete Layout   Removes a layout.
Display
Command
Keyboard/Mouse Shortcut
Function
Table View
Ctrl1
Switches to table view.
2D
Ctrl2
Switches to two-dimensional view.
3D
Ctrl3 Switches to three-dimensional view.
Slideshow of Selected Features
  Switches to slideshow view.
Background Color
CtrlB
Opens a dialog for selecting a new background color in the View window.
Background Map
Presents options for Viewing Data with a Background Map.
Show End Nodes
Shows the starting and ending coordinates of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Viewing Start and End Coordinates.
Show Coordinates
Shows the coordinates of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Marking Coordinates.
Show Text Insertion Points
Shows the text insertion points of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Marking Text Insertion Points. To use this tool more selectively, right-click on a node in the Display Control.
Show Area Fill
When unchecked, feature type geometries with areas do not render an area filling when viewing features in the View window in 2D mode, regardless of any Fill Color or Fill Opacity settings. To use this tool more selectively, right-click on a node in the Display Control.
Refresh
F5
Reloads the data from the source.
The FME Data Inspector will close the dataset and re-read everything in it from the source folder.
Any changes that have been made to the source dataset since it was opened in the FME Data Inspector will be updated in the View window when the dataset is refreshed.
Note  Do not use the Refresh button when you are viewing data routed directly from FME Workbench.
Stop Data Loading
Esc
Cancels the current dataset being loaded or the current "Save" operation.
Explore
Command Keyboard/Mouse Shortcut Function
Select
CtrlK
Selects a feature and displays information in the Feature Information window.
Pan
Ctrl N
Press and hold both the left and right mouse buttons.
Move the camera view vertically and horizontally. Click and drag the pointer to pan the current dataset.
Orbit
Ctrl R
Hold down the middle mouse button.
Rotate a 3D image in the View window to inspect it from many different angles.
Note  This command is not available in 2D view mode.
Zoom In
Ctrl +
Hold down the Shift key.
Moves the view closer or farther away, by increments.
Tip  You can zoom in and out in the View window without activating the zoom tools by using the scroll wheel on your mouse.
The zoom tools are location aware; they draw the focus of the view to where you click or to your mouse location when using the scroll wheel.
Zoom Out
Ctrl -
Hold down the Ctrl key.
Measure Distances
CtrlM
Enables the measuring tool. Click and drag between two points in the View window to measure the distance between them.
Zoom to Selected Feature
Ctrl J
Concentrates the view on the selected feature.
Zoom to Full Extent
Ctrl E
Zooms the view to a distance so that the data is visible and centered in the window.
Find and Mark Location   Opens the Mark Location dialog for Marking a Location in a View.
Select All Features with No Geometry
CtrlG
Selects all features that have no geometry (for example, a database record may consist entirely of features that have an fme_type of fme_no_geom).
Filter 2D Display   Opens the Filter Features dialog for displaying only features that satisfy a set of filter conditions.
Utilities
FME Options Ctrl, Opens the FME Options dialog for configuring optional FME Data Inspector features, including Background Maps, Database Connections, Default Paths, and Web Service Connections.
Browse Readers and Writers   Opens the Reader and Writer Gallery.
Browse Coordinate Systems Alts Opens the Coordinate System Gallery.
