FME Form: 2026.1 BETA
Using Web Connections
Many processes in FME Form require you to connect and authenticate to a web service in order to use them. For example, when you use an HTTPCaller transformer, you may need to authenticate to a web service, such as Google BigQuery. Similarly, if you want to connect to an FME Flow, you must specify a set of connection parameters. Web connections provide a convenient and secure way to store and reuse these connection parameters. Each time you need to specify the same connection parameters, you can use the connection, rather than re-entering the parameters. If the connection parameters change, you can edit them in one place, rather than in each workspace that uses the connection.
Managing Web Services
FME Form must be registered to use the web services to which you want to connect. Although many of the most common web services are already registered in FME for testing purposes, we recommend defining your own for production purposes. Use Utilities > FME Options > Web Connections to manage web services. For more information, see Managing Web Services.
In other cases, FME provides only a reference template to the web service. To use the service, you must likewise provide your credentials in order to use it. If the service adheres to the OAuth 2.0 standard, you can provide these credentials dynamically when adding a connection (see Working with Web Connections in a Workspace, below).
Adding Web Connections
It is usually more convenient to add a web connection at the time you are using one in a workspace or connecting to FME Flow (see below). However, you can also add a web connection in Utilities > FME Options > Web Connections, and use it later in a workspace.
Adding Web Connections from FME Flow
If your Connection Storage setting, under Utilities > FME Options > Default Paths, is set to FME Flow, you can access the same web connections as those on the specified FME Flow. For more information, see Default Paths.
You can use an existing web connection, or define a new one, in Transformer Parameters, Add Reader, or Add Writer dialogs.
If the web service that you specify adheres to the OAuth 2.0 standard and is not yet defined in FME, a Create New <web service> dialog opens that allows you to create the service dynamically. For more information, see Managing Web Services.
Visibility: This field applies only if Database Accessibility, as specified in Utilities > FME Options > Default Paths, is Shared. Specify whether the connection is available only to yourself, or to any user of the database (Shared). For more information, click Help from the Default Paths window under Utilities > FME Options.
Using Web Connections to Connect to FME Flow
To connect to FME Flow, you can use a web connection that specifies the FME Flow web service. You can use an existing connection, or define a new one, in the publish or download wizard. For more information, see Connecting to FME Flow.
To create a new connection in a transformer, such as FME FlowJobSubmitter, and use it right away, select Add Web Connection.
In the FME Flow Connection dialog, specify:
- Web Service: FME Flow
- Server URL: The URL of the FME Flow. For more information, see Accessing the Web User Interface in the FME Flow documentation.
- Authentication: The method for authenticating with FME Flow.
- Basic: Authenticate with the specified User Name and Password of an FME Flow user.
- Azure AD: Authenticate with the Azure Active Directory credentials of an FME Flow user.
- Windows Credentials: Authenticate with Integrated Windows Authentication ("single sign-on"). You must be logged in to Windows with credentials that are imported to FME Flow from a Windows Active Directory connection and are enabled for single sign-on. For more information, see Configuring Integrated Windows Authentication in the FME Flow documentation.
- Azure AD Connection: If Azure AD is specified above, specify the Azure AD web connection to use for this connection. For more information, see Create an FME Flow Azure Active Directory Web Connection in FME Form.
Reusing a Web Connection
