GDAL Generic Raster Quick Facts
Format Type Identifier |
GDAL_GENERIC_RASTER |
Reader/Writer |
Reader |
Dependencies |
None |
Dataset Type |
File |
Feature Type |
GDAL_GENERIC or <source_dataset_filename> |
Typical File Extensions |
Varies per format. See the GDAL format list for details. |
Automated Translation Support |
Yes |
User-Defined Attributes |
Coordinate System Support |
Varies per format. |
Generic Color Support |
Spatial Index |
Schema Required |
Transaction Support |
Geometry Type |
gdal_generic_raster_type |
GDAL Generic Raster Geometry Support
| Geometry | Supported? |
aggregate |
no |
circles |
no |
circular arc |
no |
donut polygon |
no |
elliptical arc |
no |
ellipses |
no |
line |
no |
none |
no |
point |
no |
polygon |
no |
raster |
yes |
solid |
no |
surface |
no |
text |
no |
z values |
yes |
GDAL Generic Raster Support
Band Interpretations |
Red8, Red16, Green8, Green16, Blue8, Blue16, Alpha8, Alpha16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64 |
Palette Key Interpretations |
UInt8, UInt16, UInt32 |
Palette Value Interpretations |
RGBA32 |
Nodata Value |
Varies, depending on the GDAL format being read. |
Cell Origin (x, y) |
Rotation Support |
GCP Support |
World File Support |
TAB File Support |
