FME Form: 2025.2 BETA
Sharing Custom Transformers
When a Custom Transformer is exported, it retains all of its properties, so you can distribute it much like any other file.
E-mailing a custom transformer:
To e-mail a custom transformer directly from FME Workbench, open the transformer file and select File > Send To.
This opens a new e-mail message in your default e-mail client, with the transformer attached. The default subject line is the local path to the transformer.
Note  You can also send the transformer by browsing to your default Transformers folder and attaching it directly to a message.
Sharing transformers through a network:
If you have set up a shared folder, any transformers in the Transformers folder are updated each time you start FME Workbench.
