FME Flow: 2025.2 BETA
Default User Accounts and Passwords
The FME Flow installer creates the following user accounts by default:
Note  The default Status of these accounts, except the admin account, is Disabled.
Username/Password Description Default Status Role
admin/admin Access to all FME Flow resources.
Note  You are prompted to update the admin password upon initial use, based on the default Password Policy configuration.
Enabled fmeadmin, fmesuperuser
author/author An account intended for FME Workbench authors. Disabled fmeauthor
guest/guest An account that provides the minimal access to FME Flow required to run workspaces. Disabled fmeguest
user/user An account intended for the FME Flow Web User Interface. Disabled fmeuser
See Also
