FME Flow: 2025.2 BETA
Configuring FME Flow as a System Service (Linux)
You can configure FME Flow as a system service that starts when you start your system. You should do this only if you have set up system services before and understand the different run levels on your system.
Warning  Configuring scripts to run at start-up on Linux is an advanced task. The steps for doing so vary, depending on your configuration. Use the steps listed in this section as a guide only.
FME Flow is composed of a series of components, and each component has its own scripts. Both systemd and SysV scripts are provided.
