FME Transformers: 2025.1
Categories
Format Specific
Related Transformers
JSONExtractor
JSONFlattener
JSONFormatter
JSONFragmenter
JSONTemplater
JSONUpdater
JSONValidator
YAMLtoJSONConverter
 Converts YAML to JSON.
  • Converting YAML for use with JSON transformers in FME.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
  • Run Once: When no input features are connected, the transformer runs one time.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the YAMLtoJSONConverter on the FME Community.
