FME Transformers: 2025.1
WordToDocumentPDFStyler
Prepares Microsoft Word format for use in the Document PDF Writer.
- Preparing Word format for PDF output.
The WordToDocumentPDFStyler transformer restyles MSWord format attributes into format attributes suitable for the Document PDF Writer, handling text, headings, tables, images, lists, page breaks, and font formatting.
For more information regarding PDF styling, see the PDF Writer chapter in the FME Readers and Writers help. (In FME Workbench, select Help > FME Readers and Writers.)
Features with Microsoft Word format attributes for restyling.
Features with restyled format attributes.
If an error occurs, the feature will be output via the <Rejected> port. In addition, an error message will be set in the attribute named by the Error Attribute parameter.
This transformer has no parameters to configure.
Search for all results about the WordToDocumentPDFStyler on the FME Community.
