FME Transformers: 2025.1
UniqueIdentifierGenerator
Calculates a UUID (Universally Unique IDentifier) or ULID (Universally Unique Lexicographically Sortable Identifier) for each incoming feature, and adds it as an attribute.
UUIDs are expressed as a string consisting of 8 hexadecimal digits, followed by a hyphen, then three groups of 4 hexadecimal digits, each followed by a hyphen, then 12 hexadecimal digits. It is 36 bytes in size. UUIDs look like:
7672aac8-fa0b-464c-b0b8-3efa9ae9cd86
UUIDs may be optionally output with curly braces (GUIDs).
ULIDs are expressed as a string consisting of 26 characters. For more information, see Universally Unique Lexicographically Sortable Identifier. Note that FME does not use a “cryptographically secure” source of randomness for ULIDs and thus the output may not be appropriate for some purposes.
This transformer is similar to the GOIDGenerator, which generates a unique ID for each feature partially based on that feature's geometry.
Unique Identifier Type |
Select a format for the ID string:
Generated ID |
Name the attribute to contain the ID. |
Dependencies | None |
Aliases | UUIDGenerator ULIDGenerator GUIDGenerator |
History |
Search for all results about the UniqueIdentifierGenerator on the FME Community.
