FME Transformers: 2025.1 BETA
Categories
3D
3D
Geometries
TINGenerator
Constructs a Delaunay triangulation based on input points and breaklines. The surface model may be output in a number of representations: a triangulated irregular network (TIN), TIN vertices, TIN edges, and triangles.
Example
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the TINGenerator on the FME Community.
