FME Transformers: 2025.1
OpenAPICaller
Accesses an API endpoint defined by an OpenAPI specification via HTTP or HTTPS.
Import from OpenAPI Specification
This transformer is configured by importing an OpenAPI specification JSON or YAML file.
- Use the Select button to access the Import from OpenAPI Specification dialog.
- Provide the file location in the Specification parameter, either with a URL including the .json or .yaml file, or by selecting a downloaded file.
- Select from the available endpoints, and the OpenAPICaller dialog will be populated as specified, including Full Request URL, Authentication Method, and request details such as Query String Parameters and Headers.
Note that any selections made here will overwrite current parameter values.
In this example, we will configure an OpenAPICaller to retrieve a list of available emojis from Trello via their OpenAPI specification.
In the parameters dialog, use the Select button to access the import dialog.
In the import dialog, we navigate to the previously-downloaded specification file.
One the specification file is selected, available Endpoint options are populated.
We select the emoji endpoint, and its GET method. Note the applicable Query Parameters are also retrieved.
Import Request Parameters will apply the selections to the appropriate OpenAPICaller parameters.
The applicable parameters have been configured.
To test the configuration, we use the Send Test Request button.
In the test request dialog, a preview of the query is shown.
Note that if there were any user parameters in the query, they would be available and editable for testing.
Send Test Request will execute the query.
The query test results are returned in Test Response Preview.
These results (and any configuration changes made to user parameters, if present) are saved for future reference but will not affect the transformer's actual parameter settings.
The HTTP response body may be saved to an attribute, or a file. By default the body is saved to the attribute identified by the Response Body Attribute parameter.
The HTTP response status code will be stored in the attribute named by the Status Code Attribute parameter. By default this is the _http_status_code attribute. For more information on HTTP Status Codes, please refer to https://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html.
In addition, the HTTP response headers will be saved in the list attribute specified by the Multipart Header List Attribute parameter. By default the headers are stored in the _headers{} list attribute. For a list of common HTTP response headers, please refer to https://en.wikipedia.org/wiki/List_of_HTTP_header_fields.
If an error occurs while accessing the URL, the feature will be output via the <Rejected> port. In addition, an error message will be set in the attribute named by the Error Attribute parameter.
Authentication |
If enabled, provide authentication details as needed.
URL by Parameters |
This group divides up the Full Request URL into several components which can be edited separately. Any changes made to these parameters will be reflected in the value of the Full Request URL parameter.
Full Request URL |
This parameter identifies the URL which will be accessed by the transformer. The URL can be edited directly in this parameter, or by editing the parameters in the URL by Parameters group above. Any changes made to this parameter will be reflected in the URL by Parameters group. |
Headers |
This table can be used to create custom HTTP headers which will be sent along with the request. This can be used to customize the request that FME will make to the server. Header names and values can be entered directly or constructed from attribute values. In addition, the Name column provides a list of commonly used header names. |
Body |
These parameters are only enabled when HTTP Method is PUT, POST, DELETE, or PATCH. An upload body is not required; for example, DELETE requests often have no upload body.
Response Handling Mode |
This parameter allows users to determine how the HTTP response body should be processed. |
Output JSON Fragments as Features |
When Response Handling Mode is Ouput JSON Fragments as Features, this mode performs JSON post processing on the response body, equivalent to inserting JSONFlattener and JSONFragmenter transformers after the OpenAPICaller. The object keys and values contained within the response body will be extracted into FME feature attributes. The response body can optionally be split up into multiple features using the JSON Query to Fragment parameter. If the response body does not contain valid json the feature will be output through the <Rejected> port.
Save Entire Response Body |
When Response Handling Mode is Save Entire Response Body, this parameter allows users to set the destination for the HTTP response body.
Note If you are downloading a very large response body with the OpenAPICaller, it is recommended that you save it to a file. This avoids creating a large attribute on the feature.
Response Header and Status Attributes |
Multipart Response Handling |
It is rare, but possible for an HTTP server to return a multipart response. That is, a single HTTP request will result in an HTTP response which contains several different parts. A multipart response will have a Content-Type header which begins with "multipart", such as "multipart/mixed". The OpenAPICaller has the Feature Output option to split such responses into multiple features. Because multipart responses are very rare, the default behavior is to not split multipart responses into multiple features. These parameters are only enabled when response bodies are being saved to attributes, or to a folder.
Concurrent Requests |
Retry Failed Requests |
When enabled, the OpenAPICaller will attempt to retry requests which have failed, or have returned an HTTP error.
Rate Limiting |
HTTP Client Options |
HTTPS Client Certificate |
In a typical HTTPS connection, the server provides a certificate which is authenticated by the client. This ensures that the connection is secure. It is also possible for the client to authenticate themselves to the server via a certificate, called a client certificate. This is called “Mutual TLS” and it allows the server to only accept connections from clients with a valid certificate. This type of authentication is rare, typically only used when advanced security is required. When using a client certificate, a private key is also required.
Advanced Security |
Specification |
Specify a JSON or YAML OpenAPI specification file to use. |
Select Endpoint |
Select an available option to have its details populated in the main parameter dialog. |
Dependencies | None |
Aliases | |
History | This transformer replaces Import from OpenAPI feature in the HTTPCaller. |
Search for all results about the OpenAPICaller on the FME Community.
