FME Transformers: 2025.1
NLPTrainer
Trains a natural language processing (NLP) classification model based on the user’s specifications and the provided data.
NLPTrainer expects tagged data as input, with each feature bearing a single text and label. Some preprocessing of this learning data may be required, and the AttributeCreator transformer can be useful for this. Based on the set of learning data and the NLP features (specific types of information about the text) that the user specifies, a model will then be created and written to a *.fmd (FME MoDel) file. The companion transformer to this one, NLPClassifier, uses these *.fmd files to perform natural language classification, sorting texts into the categories labeled in the training data.
- For more information about natural language processing with FME, see the documentation for the companion NLPClassifier transformer.
All incoming features should have the same attribute names for each of the required pieces of information, both the label and the text. For example, if one of the input features uses 'my_label' as an attribute name for the label and 'my_text' as the attribute name for the text, all the other input features should use 'my_label' for labels and 'my_text' for texts as well.
This port will output one feature after the training process is over. The feature’s attributes will indicate the sizes of the test and training sets of data, as well as the accuracy of the model over the test set (on a scale of 0 to 1, where 1 is perfect accuracy), and some information about what NLP features the model finds helpful. (The exact structure of this information depends on the model type.) This information can be easily reviewed by connecting a logger.
Features which cannot be used to train the model, often because either the text itself or the label cannot be retrieved, are routed to this port.
Model Type to Train |
This parameter specifies what kind of model the NLPTrainer will produce. All model types are suitable for use with the NLPClassifier transformer. |
Label |
The attribute on incoming features which specifies the label. |
Output Model Filename |
The save location for the model, in the form of an *.fmd file. |
Text |
The attribute on incoming features which specifies the text. |
Case Sensitive |
Determines whether the model will be case sensitive or not. |
Data Percentage for Testing |
Determines what percentage of the input data will be used for testing the completed model. The remainder of the input data will be used for training. |
Text Type |
Indicates whether this model is being trained to look at single-word or multiword texts. |
NLP Features |
Allows the user to tell the NLPTrainer what information about the text to take into account. Different NLP feature specifications will produce different models, which may vary considerably in their accuracy.
Yes |
| Dependencies | |
| Aliases | NaturalLanguageProcessingTrainer |
| History | Released FME 2019.0 |
Search for all results about the NLPTrainer on the FME Community.
