FME Transformers: 2025.1 BETA
Categories
Geometries
MultipleGeometrySetter
Provides the ability to set up an aggregate where each part is independent from the others, and its own complete geometry.
For example, if an aggregate enters and it contains two parts, a line and a polygon, it will leave containing the same two parts, but the difference will be that each part should now be interpreted as its own separate geometry. For example, a database writer that supports this concept may then write out each of the multiple geometries to its own geometry column.
About Multiple Geometry
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases IndividualGeometriesSetter
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the MultipleGeometrySetter on the FME Community.
