FME Transformers: 2025.1 BETA
LengthToPointCalculator
Calculates the length of a feature from its start until the closest spot to a point, and adds it as a new attribute. The point coordinates are taken from attributes in the original feature.
The length is calculated along the feature up until the spot on the feature that is closest to the given point.
To calculate the length of the entire feature, use the LengthCalculator.
To calculate the distance from the start of the line to each vertex, use the MeasureGenerator.
Features to be measured.
Features with an added Length Attribute as specified in parameters.
The dynamic <Rejected> port appears when a parameter is set to a non-literal value that might make processing impossible.
For example, if a numeric parameter such as Line Width, Count Start, or Decimal Places is set to an expression, attribute value, or user parameter, it is possible to pass in a non-numeric value that cannot be used. Decimal Places = Cat cannot be processed, so the feature will be output via this port.
Rejected features will have an fme_rejection_code attribute explaining the reason for rejection.
Note Feature order may change in relation to other output ports. Feature order per port is maintained.
Length Dimension |
By default, the 2-dimensional length of the line is calculated, and any Z values, if present, are ignored. To have a 3D length calculated, the length dimension parameter should be set to 3, and then the elevations will be included in the length computation. |
X Value Attribute |
The feature attribute from which to derive the x-value point coordinate. |
Y Value Attribute |
The feature attribute from which to derive the y-value point coordinate. |
Z Value Attribute |
The feature attribute from which to derive the z-value point coordinate. |
Length Attribute |
Name of the attribute to hold the length value that is calculated. |
Dependencies | None |
Aliases | |
History |
Search for all results about the LengthToPointCalculator on the FME Community.
