FME Transformers: 2025.1
ExcelConditionalFormatter
Sets conditional rules and styles on features destined for Excel formats.
- Preparing data for presentation in Excel.
The ExcelConditionalFormatter creates a Conditional Formatting rule that can be managed in Excel using the Conditional Formatting Rules Manager dialog.
Multiple rules can be added by chaining additional transformers together.
When adding multiple attributes to the rule, values such as average, rank, unique or duplicate values are evaluated across the entire combined range and not just the single attribute column.
- Excel formulas that return an error will not apply the style. Testing formulas in Excel is recommended.
- For more information regarding Excel styling, see the FME Readers and Writers help topic Microsoft Excel Writer Parameters. In particular, see the Formatting section under Usage Notes.
Apply to |
Select the range to apply this rule to:
The entire combined range is used to compute the values of the conditional format rule. |
Selected Attributes |
When Apply to is Selected Attributes as One Combined Range, select one or more attributes to apply the conditional rule. If a header row is written it will be automatically excluded from the rule. |
Type |
Select a rule type to define:
Format Style |
Select a style:
Selected |
Select the range to apply this |
Format
Specify values and colors for each point in the gradient - Minimum, Maximum, and Midpoint (when Format Style is 3-Color Scale).
Type |
Value Formula |
As applicable, provide a value or Excel formula.
Color |
For each point, select a color. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
* Color interpretation may vary in other contexts such as raster bands and palettes. |
Format Only Cells With
Value Matching a Comparison Condition |
Highlight cell values using a numeric comparison operator.
Text Matching a Comparison Condition |
Highlighting based on specific text.
Dates Occurring |
Highlight cells based on a relative date range.
Blanks |
Style cells that are empty. |
No Blanks |
Style cells that are not empty. |
Errors |
Style cells containing an error. Error values include: #####, #VALUE!, #DIV/0!, #NAME?, #N/A, #REF!, #NUM!, and #NULL!. |
No Errors |
Style cells that do not contain an error. |
Format Values Ranked In |
Select the type of ranking:
Rank Value |
Specify the top or bottom number. Valid values are between 1 and 1000 as items, between 1 and 100 for percentage. |
Rank By |
Select a ranking method:
Format Values |
Style cells based on the average or number of standard deviations from the average of the selected cells:
Format All |
Style cells with:
Custom |
Defines a custom number format string for the cell. This value will override any format string in the cell for an existing sheet or template sheet. The custom format string can be created using Microsoft's rules for creating a custom number format. Custom number string examples:
The Custom field also supports a set of commonly used standard formats used in Excel. Note that these common values may display with a prefix resembling [$-409] and/or a suffix resembling ;@. These additions exist to ensure that these number formats are properly recognized as standard formats once written to Excel, instead of custom format strings. |
Style |
Select a font style to apply:
Underline |
Select an underlining style to apply:
Strikethrough |
Select a strikethrough style to apply:
Color |
Select a text color to apply. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
Border Style |
Select a border pattern to apply. |
Border Color |
Select a border color to apply. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
Background Color |
Specify the background color of the Pattern Style selected. To set the background color of the cell, set the Background Color and the Pattern Style to Solid. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
Pattern Color |
Specify the foreground color of the pattern. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). In the case of (1,1,1) which is valid for both 24-bit and decimal, the decimal interpretation (white) is generally used when specifying colors*. Hex codes are accepted with or without a hash sign (#).
Pattern Style |
Specify the pattern used to fill the cell, using the colors from Pattern Color and Background Color. |
Search for all results about the ExcelConditionalFormatter on the FME Community.
