FME Transformers: 2025.1 BETA
Categories
Attributes
Related Transformers
AttributeCopier
AttributeCreator
AttributeKeeper
AttributeManager
AttributeRenamer
AttributeValueMapper
BulkAttributeRemover
BulkAttributeRenamer
AttributeRemover
Removes the selected attributes and list attributes from the feature.
Jump to Configuration
  • Cleaning up features with small numbers of unnecessary attribute
  • Improving performance by removing unneeded attributes
Once connected to input features, the AttributeRemover provides pick lists (one for attributes and one for list attributes) for you to choose which specific attributes to remove. All other attributes are kept, and the modified features are output.
  • Consider using the AttributeManager instead
  • Use the BulkAttributeRemover to remove all attributes that match a pattern.
  • Use the AttributeKeeper to keep selected individual attributes on a feature.
  • Removing attributes can improve FME Workbench performance, making translations run more efficiently and the FME Workbench interface respond more quickly.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases ListRemover
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AttributeRemover on the FME Community.
