FME Transformers: 2025.1 BETA
Categories
3D
3D
Geometries
Spatial Analysis
Related Transformers
Clipper
Snipper
3DSlicer
Slices geometry along a specified plane.
Jump to Configuration
  • Slicing solids, surfaces, and other 3D geometry with a plane.
The 3DSlicer accepts features with any geometry type and splits them along a specified 3D plane.
Both 3D and 2D geometries are accepted, including points clouds and aggregates. 2D features are handled as 3D with a Z coordinate of zero (0). Aggregates are treated as single objects.
Output features are identified as being on the front or back side of the slicing plane, and are flagged as having been sliced or not. Front and back are relative to the plane, with front being in the direction of the plane's normal vector and back being the inverse. Features that are entirely coincident with the plane are considered to be on the front side.
The slicing plane is defined by:
  • Fixed X, Fixed Y, or Fixed Z: Specifying a single axis point in ground units. The normal vector of the plane (determining front and back) is in the positive direction along the fixed axis.
  • Point and Normal: Specifying a single 3D point on the slicing plane and another point defining the direction of the normal vector from that point.
Plane Type
Orientation
Fixed X
Fixed Y
Fixed Z
Point and Normal
Variable orientation
  • Only 3D plane geometry may be used to slice.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the 3DSlicer on the FME Community.
