Microsoft SQL Server Azure (JDBC) Reader/Writer
FME can read and write spatial and attribute data held in Microsoft SQL Server database tables.
FME provides read and write access via Microsoft's JDBC driver, which is bundled with FME.
We have improved the user experience by merging spatial and non-spatial formats. Previous format identifiers:
  • Microsoft SQL Server Non-Spatial (JDBC) Reader/Writer: MSSQL_JDBC_AZURE_NONSPATIAL
  • Microsoft SQL Server Spatial (JDBC) Reader/Writer: MSSQL_JDBC_AZURE_SPATIAL
Product and System Requirements
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
Yes
Yes
Yes
Yes
Writer
Yes
Yes
Yes
Yes
Yes
Yes
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
Tip  To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
Memory Usage (applicable to writers only): Changing the value in the writer parameter Features Per Transaction can control the number of features that FME places in each transaction before a transaction is committed to the database.
