Microsoft Azure SQL Database Reader/Writer
FME can read and write spatial and attribute data held in live Microsoft SQL Server database tables.
FME provides read and write access to live Microsoft SQL Server databases via Microsoft's ActiveX Data Objects (ADO).
We have improved the user experience by merging spatial and non-spatial formats into a new Microsoft Azure SQL Database Reader/Writer. Previous format identifiers:
  • Microsoft Azure SQL Database Non-Spatial Reader/Writer: MSSQL_AZURE
  • Microsoft Azure SQL Database Spatial Reader/Writer: MSSQL_AZURE_SPATIAL
Product and System Requirements
Dependencies
– Microsoft OLE DB Driver 19.x for SQL Server
– Microsoft System CLR Types for SQL Server 2012 (installed with FME except in silent installs)
– Microsoft .NET Framework v4.5.2
FME connects to SQL (Azure) Servers first using Microsoft OLE DB Driver 19.x for SQL Server. If the OLE DB Driver is not found, FME tries to connect again using the 2012 Native Client.
The 2012 Native Client supports SQL Server 2005 and above, including Azure Servers.
The 2008 Native Client supports SQL Server 2005 and above, but does not support Azure Servers.
For spatial reading and writing, Microsoft System CLR Types for SQL Server 2012 and Microsoft .Net 4.5.2 are required.
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
No
Yes
No
No
Writer
Yes
Yes
No
Yes
No
No
Reader Overview
Click the Reader Parameters button and establish a Microsoft Azure SQL Database connection.
FME considers a database dataset to be a collection of relational tables. Arbitrary where clauses and joins are fully supported.
Writer Overview
Click the Writer Parameters button and establish a Microsoft Azure SQL Database connection.
The writer module stores attribute records into a live relational database. The writer provides the following capabilities:
  • Transaction Support:The writer provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
  • Table Creation: The writer uses the information within the FME workspace to automatically create database tables as needed.
