Google Sheets v4 Reader Parameters
Service Connection
About Web Connections |
Connections store authentication information. For general information about web connections, please see Using Web Connections. For information about managing web services (including authorization credentials such as Client Id and Client Secret), please see Managing Web Services. Connection From the Connection parameter in a web service format, you can do one of the following:
Constraints
Specifies the spreadsheet to read:
- Spreadsheet Name: The user’s Google Drive is searched for a spreadsheet that exactly matches the given name. Search scope is limited to My Drive. It is an error if more than one match is found.
- Spreadsheet URL: For example, https://docs.google.com/spreadsheets/d/{spreadsheet_id}/edit. The portion of the URL following the spreadsheet ID is ignored.
Click the Browse button to view a list of worksheets under the selected spreadsheet.
The selected worksheets will be added to the workspace.
Schema Generation
These parameters influence the schema generated for the feature types when they are first added to the workspace. In addition, the values supplied here are copied to the corresponding feature type parameters when the reader is initially added to the workspace.
Optional
The row number that contains the field names. If not specified, then field names are column letters from Start Column to End Column.
Optional
The row number of the first feature. The value must be greater than Field Names Row. If not specified, this is assumed to be either 1 or Field Names Row + 1, whichever is greater.
The column from which to start reading and/or mapping field names to user attributes. Must be a value between A and ZZZ.
The column at which to stop reading and/or mapping field names to user attributes. Must be a value between A and ZZZ. The reader will read up to and including this column.
Value Options
The values supplied here are copied to the corresponding feature type parameters when the reader is initially added to the workspace.
- Missing – The attribute is not added to the feature if its value is blank.
- Null – Blank values are set on the feature with a null value.
- Empty String – Blank values are set on the feature as an empty string.
- Formatted Value – Read calculated and formatted values. In this context, this excludes text formatting such as bold and italics.
- Unformatted Value – Read calculated but unformatted values.
- Formula – Read uncalculated and unformatted values.
- Serial Number – Read date, time, datetime, and duration values as a decimal, where the whole number portion represents days after 1899-12-30, and the fractional portion as a fraction of a day.
- Formatted String – Read date, time, datetime, and duration values as they appear in the web interface.
Schema Attributes
Use this parameter to expose Format Attributes in FME Workbench when you create a workspace:
- In a non-dynamic scenario, this parameter allows you to expose additional attributes on multiple feature types. Click the browse button to view the available format attributes (which are different for each format) for the reader.
