Foursquare Studio Data: Add Web Connection
Foursquare Studio Data Authentication
Using the Foursquare Studio Data Reader/Writer requires a Foursquare Studio Web Connection. Using this format always requires authenticated access.
Foursquare Studio Web Connections require the refresh token for your Foursquare Studio account.
- To retrieve your refresh token, visit https://studio.foursquare.com/tokens.html.
To define a new connection from the Unfolded Connection parameter:
- Select Add Web Connection. See database-specific parameters below, as well as the section To Use a Web Connection in a Workspace in Using Web Connections. The new connection can be made visible only to the current user, or can be shared among multiple users.
Web Service
Foursquare Studio (safe.Unfolded)
Connection Name
Enter a name for the new connection.
Foursquare Studio (safe.Unfolded) Parameters
Refresh Token
Foursquare Studio API Client ID
This is the client ID which will be used to make refresh token exchange requests. This value should be set to the default Foursquare Studio REST API Client ID provided in the web service definition.
