DocumentPDF Format Attributes
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
See below for information about Markdown Syntax and Font Usage.
Attribute Name
Contents
documentpdf_borders_layout
Sets the visible table borders.
Values:
All
NONE
INTERNAL
MINIMAL
HORIZONTAL_LINES
NO_HORIZONTAL_LINES
SINGLE_TOP_LINE
documentpdf_column_layout_count
Adds the element to a multi-column layout, grouping it with other elements that have the same attribute value.
This attribute specifies the total number of columns in the layout.
Elements are placed into columns from left to right. Once a column is full, placement continues in the next column. When all columns on a page are full, the layout continues on a new page.
documentpdf_footer_center
Sets text for the center of the footer.
documentpdf_footer_left
Sets text for the left side of the footer.
documentpdf_footer_right
Sets text for the right side of the footer.
documentpdf_heading_level
Sets the heading level for the text.
Values:
1
2
3
4
documentpdf_header_center
Sets text for the center of the header.
documentpdf_header_left
Sets text for the left side of the header.
documentpdf_header_right
Sets text for the right side of the header.
documentpdf_image_caption_position
Sets the position of the image caption.
Values:
top
bottom
documentpdf_image_link
Makes the image a clickable link to the provided destination.
Heading Link
Link to a heading inside the document. Preceded by a # symbol (for example, #PDF Heading)
Note  The link is case-sensitive and must contain all the characters of the heading, including spaces.
Page Link
Link to a page inside the document (for example, 3)
External Link
Link to an external URL (for example, https://google.com)
documentpdf_image_filename
Specifies the path and filename of the image.
documentpdf_image_width
Specifies the width of the image.
The height will scale to retain the same aspect ratio. If blank, use the image’s native width.
documentpdf_image_width_unit
Specifies the unit of documentpdf_image_width.
Values:
  • Points – pt
  • Centimeters – cm
  • Inches – in
  • Percent of page or column width – %
documentpdf_list_item_indent_level
Specifies the indent level of the list item.
documentpdf_list_item_order
Indicates whether the list item is ordered with numbers or unordered with bullets.
Values:
  • unordered
  • ordered
documentpdf_outer_border_width
Sets table outer border width if outer border is visible.
documentpdf_page_orientation
Sets the orientation of all following pages.
Values:
  • landscape
  • portrait
documentpdf_page_size
Sets the page size of all following pages.
Values:
  • A3
  • A4
  • A5
  • letter
  • legal
  • Custom size – {width},{height}
documentpdf_page_size_unit
Set the unit of the specified width and height.
If documentpdf_page_size is a custom size, this is required.
Values:
  • Centimeters – cm
  • Inches – in
  • Millimeters – mm
  • Points – pt
documentpdf_table_row_headings
Attribute list containing the text to appear in the first row of the table as column headings.
To be part of the same table, every table_row must have the same documentpdf_table_row_headings attribute.
documentpdf_table_row_values
Attribute list containing the text to appear in a row of the table.
documentpdf_table_row_widths
Attribute list containing the widths of each column in percent of page width.
If set to stretch, the column will split the remaining page width among all stretch columns. Only the first table_row’s widths will be used.
documentpdf_text
Sets the text for the element.
documentpdf_type
Sets the type of the element.
Values:
heading
Required
documentpdf_text
Styles
text
Required
documentpdf_image_path
Optional
documentpdf_text
Styles
text, image
list_item
Required
documentpdf_text
Optional
Styles
text, list
page_break
Optional
page_properties
Optional
documentpdf_watermark_text
Styles
text, watermark
paragraph
Required
documentpdf_text
Optional
Styles
text
table_row
Required
Optional
Styles
text, heading, table
table_of_contents
Styles
text, heading
title
Required
documentpdf_text
Optional
Styles
text
Formatting Attributes
Formatting Attributes allow styling aspects of each element. Some elements support more than one group of formatting attributes. These are distinguished by the suffix text, heading, table, or image.
Note  A suffix is required.
Attribute Name
Contents
documentpdf_align_{text, heading, table, image}
Specifies the text alignment.
Values:
LEFT
CENTER
RIGHT
JUSTIFY
Note for Tables: The first table row’s “text” alignment sets alignment for the entire table.
Note for List Items: CENTER and RIGHT default to LEFT.
documentpdf_font_color_{text, heading}
The color of the text.
Overrides fme_color.
Three comma-separated numbers from 0 to 1 for red, green, and blue.
Example: 1,0.5,0.125
documentpdf_font_emphasis_{text, heading}
Sets the emphasis of the font ( bold, italic, underline, and strikethrough).
String containing any combination of “BIUS”.
Example: BUS
documentpdf_font_family_{text, heading}
The name of the font to use for the text.
Will search the system for fonts to embed in the PDF.
documentpdf_font_fill_color_{text, heading}
The background color of the text.
Overrides fme_fill_color.
documentpdf_font_line_spacing_{text, heading}
Defines the spacing between lines of text.
Multiplier. 1 has no effect.
Note for Headings: Line spacing has no effect.
Note for Tables: The first table row’s “text” line spacing sets line spacing for the entire table.
documentpdf_font_size_{text, heading}
The size of the font, in points.
Note for Tables: The first table row’s “text” font size sets the font size for the entire table.
documentpdf_opacity_{watermark}
A number from 0.0 to 1.0 specifying opacity.
A value of 0 is completely transparent.
documentpdf_padding_bottom_{text, heading, table, image, list}
The amount of padding at the bottom of the element, in points.
documentpdf_padding_left_{text, heading}
The amount of padding at the left of the element, in points.
Only supported for tables.
documentpdf_padding_right_{text, heading}
The amount of padding at the right of the element, in points.
documentpdf_padding_top_{text, heading, table, image, list}
The amount of padding at the top of the element, in points.
fme_color
Overridden by documentpdf_font_color_{text, heading}.
Three comma separated numbers from 0 to 1 for red, green, and blue.
Example: “1,0.5,0.125”
fme_fill_color
Overridden by documentpdf_font_fill_color_{text, heading}.
Markdown
Text input supports the following markdown syntax for inline formatting and linking.
Syntax and Example
Description
**bold**
Use double asterisks to bold text.
__italic__
Use double underscores to italicize text.
--underline--
Use double hyphens to underline text.
~~strikethrough~~
Use double tildes to strikethrough text.
\**bold\**
Use backslashes (\) to escape a character sequence (for example, if it would be incorrectly interpreted as a formatting marker).
Markdown Links
Note  documentpdf_type title does not support markdown.
Link to external URL
[link](https://google.com)
Adding a plain URL without markdown syntax still creates a clickable link; however, since the link text will not be colored blue or underlined, using markdown syntax is always recommended.
Link to page
[link](3) links to page 3
Link to heading
[link](#Heading Text) links to the heading with text “Heading Text”
Ensure Consistent Font Usage Across Systems
When generating PDFs, different systems may have different sets of installed fonts. As a result, a workspace that produces a document with one set of fonts on a local machine may produce a different-looking document when run on another system, such as when the workspace is published to FME Flow.
To avoid inconsistencies and ensure that documents render exactly the same across all environments, you can configure DocumentPDF to load fonts from a specific folder instead of relying on system-installed fonts.
This is achieved by setting the documentpdf_custom_font_dir attribute.
Value: A path to a folder containing the required font files.
Specifies the folder path from which DocumentPDF will load fonts.
When set, DocumentPDF will search only the specified folder for font files – it will no longer search the system font folders. This guarantees that the same fonts are used consistently across all systems where the workspace is run.
Important  All fonts must be present in the specified folder. If a font is missing, font loading will fail and the document may not render correctly.
