Esri ArcGIS Feature Service – Writer Feature Type Parameters
To access feature type parameters, click the gear icon Tip To always display the editor in FME Workbench, you can select View > Window Layout > Parameter Editor.
General All feature types share similar General parameters, which may include Feature Type Name, Reader or Writer information, and Geometry. In most Writer Feature Type parameter dialogs, you can also control Dynamic Schema Definitions. Some database formats accept Table or Index Qualifier prefixes on the output table feature type. |
Layer
This parameter specifies how features will be written into the destination table. Supported feature operations are described below. Note that the described behavior can be dependent on the selected options, as well as the underlying table properties.
- More information about Feature Operations.
Option |
Description |
If the Row Does Not Exist |
If the Row Exists |
Insert |
The writer appends a new row to a table using input feature attributes. |
The writer creates a new row using input feature attributes. |
Not always applicable: if the table does not have a unique key or it has an automatically generated unique key, insertion is always possible. The database cannot violate its key constraints; therefore, errors can occur on row insertion. For example, if there is a unique key and a user specifies the value with the feature, and the feature already exists, then FME Workbench logs an error. This error might be in the form of a rejected feature, or the database may stop processing altogether. |
Update |
The writer updates existing row(s) in a table using Object IDs. |
The writer rejects the input feature or logs an error if it is unable to continue. |
The writer only changes values of the existing row(s) corresponding to the input feature that differ from the input feature. |
Upsert |
The writer appends a new row or updates an existing row(s) using the attribute specified in the Upsert Match Column. |
The writer creates a new row using input feature attributes and/or geometries. |
The writer changes values of the existing row(s) corresponding to the input feature that differ from the input feature. It leaves other attributes untouched. |
Delete |
The writer deletes an existing row(s) in a table. |
The writer deletes existing row(s) corresponding to the input feature. |
fme_db_ |
The feature operation will be determined by the attribute fme_db_operation on each input feature. The value of fme_db_operation will be processed according to the steps below. Note The processing steps listed below depend on a format's available Feature Operation options.
The action depends on the operation; however, in general, if nothing is specified, the value is treated as an Insert. | The value is treated as an Insert. |
This parameter sets the handling options for Layer/Table corresponding to this feature type.
- Use Existing - Use the existing Layer, or if the feature service specified by the writer parameter does not exist, create a new Layer.
- Truncate Existing - Attempt to remove all the features or attachments in a hosted feature service Layer before writing features. If the Layer does not exist, the translation will fail.
- If the Layer supports truncation, this option supports deleting all features or attachments in a hosted feature service layer.
- If the Layer does not support truncation (or the operation fails), the writer performs a truncation by reading all feature IDs from the layer, and then making deletion requests in batches according to the advanced writer parameter Features Per Request.
This option tells the writer whether to update or skip spatial column(s) when updating features:
- Yes – The spatial column(s) specified by the user will be updated. IFMENulls will be written as null values, and will replace existing spatial values.
- No – No spatial columns will be updated.
This option tells the writer which column to match features on when using the UPSERT operation. The column selected must be a field in the layer which has both non-nullable and uniqueness constraints.
If an input feature has a null or missing value for the match column attribute, it will not be included .
This option determines whether curves in feature geometry should be preserved when written to the feature server:
- Attempt to Preserve (default) – If the feature service supports true curves, the writer will preserve true curves. If the feature service does not support true curves, feature geometry will be densified to lines before being written to the feature server.
- Yes
- No
