MapBox MBTiles Vector Tiles (MVT) Feature Representation (Format Attributes)
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
Features read from an MBTiles file consist of geometry and a series of attribute values. The attribute names are as defined in the workspace.
String attribute values are stored in UTF-8 encoding.
Attribute Name
Contents
mvt_id
Unique identifier for each source feature.
mvt_tile_column
An integer value indicating the tile number in the X direction, according to the tiling scheme, for the tile containing the current feature.
mvt_tile_row
An integer value indicating the tile number in the Y direction, according to the tiling scheme, for the tile containing the current feature.
mvt_type
The format geometry type for the feature. See Geometry.
mvt_zoom_level
An integer value between 0 and 22 that indicates the zoom level for the tile containing the current feature.
Attribute Type Mapping
Attribute Type
FME Attribute Type
string
fme_buffer
string
fme_xml
string
fme_json
string
fme_varchar(width)
string
fme_char(width)
string
fme_binarybuffer
string
fme_varbinary(width)
string
fme_binary(width)
string
fme_datetime
string
fme_date
string
fme_time
double
fme_real64
float
fme_real32
double
fme_decimal(width, decimal)
int64
fme_int64
int64
fme_int32
int64
fme_int16
int64
fme_int8
double
fme_uint64
int64
fme_uint32
int64
fme_uint16
int64
fme_uint8
bool
fme_boolean
Geometry
The geometry of MBTiles Vector Tiles features may be identified by the mvt_type attribute and correspond to 2D vector geometries. The valid values for this attribute are:
mvt_type
Description
wkb_line
2D Linear feature.
wkb_multi_line
2D Feature with multiple line geometries.
wkb_multi_point
2D Feature with multiple heterogeneous point geometries.
wkb_multi_polygon
2D Feature with multiple polygon geometries.
wkb_point
2D Point feature.
wkb_polygon
2D Simple polygon or donut feature.
wkb_unknown
An unsupported geometry type other than those listed above. This may include optional or experimental geometry types.
wkb_none
Absence of geometry. Can occur on read if there is a parsing error in the geometry
For more information about the MBTiles file specification, see the Mapbox MBTiles Specification.
For more information about vector tile data that can be stored in the tiles table, see the Mapbox Vector Tile Specification.
