LDAP/Active Directory: User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name | The name of the field to be read. |
Type |
This format supports the following field types. integer This type is used to represent 64-bit signed integers. directorystring This type is used to represent character data. distinguishedname This type is used to represent a location in the LDAP tree hierarchy. |
