Esri Geodatabase Quick Facts
Esri Mobile Geodatabase Geometry Support
Format Type Identifier |
Operating System |
Dependencies |
FME and ArcGIS must both be running on 64-bit machines.
The FME Knowledge Base article Notes on FME and Esri Versions and Compatibility contains detailed information about working with Esri-dependent formats in FME and the compatible software versions from Safe Software and Esri. Note It is worth noting that older FME versions might function with Esri versions not explicitly mentioned, but this compatibility is not guaranteed by Safe Software. The FME versions listed in the article take into account various factors, such as Python versions and other limitations. It is advised to use the latest available version of FME when possible.
Dataset Type |
Feature Type |
Feature Class name |
Typical File Extensions |
Automated Translation Support |
Yes |
User-Defined Attributes |
Yes |
Coordinate System Support |
Yes |
Generic Color Support |
Appearance Support (Surfaces Only) |
Yes |
Spatial Index |
Always |
Schema Required |
Yes |
Transaction Support |
Yes |
Geometry Type |
geodb_type |
Encoding Support |
Yes |
Geodatabase Raster Support
Band Interpretations | Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64 |
Palette Key Interpretations | UInt8, UInt16 |
Palette Value Interpretations | RGB24 |
Nodata Value | Yes |
Cell Origin (x, y) | 0.5, 0.5 |
Rotation Support | No |
GCP Support | No |
World File Support | No |
TAB File Support | No |
About FME and Geodatabase Rasters
Raster support is limited to File Geodatabases and Enterprise Geodatabases.
Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics.
FME Reading: FME supports reading raster datasets and raster catalogs. FME also supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader.
FME Writing: FME supports writing for raster datasets but not for raster catalogs or mosaic datasets.
