Feature Datasets
There are two ways to specify a Feature Dataset:
- in the Feature Type name
- using the format attribute geodb_feature_dataset (deprecated in FME 2023.1+)
Feature Type Name
The Feature Dataset name can be specified as part of the Feature Type name with the following syntax.
<Feature Dataset>/<Feature Class>
When reading:
- Feature Dataset name is optional; data can still be read even if only the Feature Class name is provided.
- By default, the Feature Dataset will be included when listing the tables. It can be excluded by selecting the reader parameter option Remove Feature Dataset.
- The <Feature Dataset> will only be used when creating a new Feature Class.
- If the Feature Class already exists, and the Feature Dataset is different from specified, a warning will be logged.
- If a <Feature Dataset> is provided, but you are writing to a non-spatial Table, then the Feature Dataset will be ignored with a warning.
Format Attribute: geodb_feature_dataset
Note that Feature Type Name takes precedence over this option.
This attribute indicates the feature dataset in which the feature originates.
- Reading – This is only present if the feature originates from a feature class that is part of a feature dataset.
- Writing – This can be specified on the first feature to indicate the feature dataset a newly created feature class should be created in. If the feature dataset did not previously exist, a new one will be created. A feature dataset provided in the Feature Type parameters will take precedence over this format attribute.
Feature Dataset Handling
This writer parameter defines the writer behavior when a Feature Dataset is provided. There are three options:
- Write Feature Dataset (default) – If a Feature Dataset is specified, it will write it if possible. (See notes above for examples of when it will not write a Feature Dataset.)
- Warn and Ignore Feature Dataset – In this mode, if a Feature Dataset is specified, a warning will be logged and the writer will treat it as if the Feature Dataset was not provided.
- Error and End Translation – In this mode, if a Feature Dataset is specified, an error will be logged and the translation will end.
