Hexagon GeoMedia SQL Server Warehouse Writer Parameters
Adding a Database Connection for Intergraph GeoMedia Access Warehouse and GeoMedia SQL Server Warehouse
Note that parameter selection may vary, depending on the format and Authentication method.
Text Options
GeoMedia Warehouse Version
Case Conversion
These parameters change the case of all feature type and attribute names in the output.
Advanced
