FME Form: 2025.1 BETA
Working with FME Flow
FME Flow is a networked data transformation application that uses the same underlying technology as FME Form. It can operate on a local-area network or over the Internet.
FME Flow has the following advantages:
- FME Form users can share translation resources through a repository mechanism.
- FME Form users can run resource intensive translations on a dedicated server.
- Non-FME users can run translations on demand.
- Translation output can be streamed directly to a chosen spatial application.
FME Flow allows users to easily share spatial data. It is scalable, so it can easily grow as demands on the system increase.
FME Flow is also a Model-Driven Architecture (MDA) meaning it processes data using predefined workflows. These workflows are defined using FME Form, making it simple to convert a desktop process to one usable by a client anywhere.
Getting Started
See Publishing to an FME Flow and Downloading from an FME Flow.
