FME Form: 2025.1 BETA
Upload Connections
If your workspace contains any database or web connections, use the Upload Connections dialog to specify the connections you want to upload. Unless previously uploaded, you must upload any connections you want to reference when the workspace runs from FME Flow.
Note  If Connection Storage is set to FME Flow, this dialog does not appear because the FME Flow already references the same connections.
Check the box for each connection you want to upload.
Click Next. If the workspace contains any FME Packages, the Upload Packages dialog opens. Otherwise, the Register Services dialog opens.
