FME Flow: 2025.1 BETA
Backing Up an FME Flow Configuration
Tip  To perform regularly scheduled backups, see Performing Scheduled Backups of an FME Flow Configuration.
  1. Click Create Backup. The Backup FME Flow page opens.
  2. Note  On earlier versions of FME Flow, this page may be named "Migration," and the interface may not match exactly the description that follows.
  3. File name: (Optional) Edit the name of the backup file.
  4. Export Location:
  5. Security Settings: If Standard Security Mode is Enabled, System Encryption is Standard (default), and you must restore to an FME Flow that uses the same encryption key as the current FME Flow you are backing up. To confirm you are in possession of that encryption key file, check Yes, I have the required encryption key.
  6. Click Save File. The backup file saves to the specified location, accompanied by a message.
See Also
