FME Flow: 2025.1 BETA
JMS Subscriber
The JMS Subscriber receives notifications from topics and relays them to Java Message System (JMS)-compliant message brokers, such as IBM WebSphere MQ.
Setting up a JMS Message Broker with FME Flow
Before configuring a JMS subscriber, you must set up a JMS broker to work with FME Flow. The steps depend on the broker you use, and are explained in the following section (applicable to both the JMS Subscriber and JMS Publisher):
Creating a JMS Subscriber for FME Flow
  1. In the FME Flow Web User Interface, select Notifications > Subscriptions, and click Create.
  2. Provide a name for the Subscription.
  3. Specify JMS for the protocol.
  4. Specify the Topics you want to subscribe to using the drop-down selector. To create a topic and use it right away, click +.
  5. Specify the JMS-specific fields for the subscriber
  6. Click OK.
Notification Content Template
The notification content template uses the following keywords in the incoming notification:
"location": "<location>"
"subscriber_content": "custom_message"
If the "subscriber_content" keyword is present, it overrides the Notification Content Template.
For example, consider the following Notification Content Template:
Hello, {Location}
If the incoming notification contains the following:
"location": "world"
The JMS subscriber sends the following message:
"Hello, world"
"location": "world"
"subscriber_content": "My custom message"
"My custom message"
See Also
