FME Flow: 2025.1 BETA
SMTP Publisher
The SMTP email publisher allows you to configure email addresses to receive messages from SMTP email clients, and publish the email data to FME Flow notification topics.
To use the email publisher, you must first make sure your FME Flow is properly configured to receive email. For more information see Configuring FME Flow to Receive Email.
Note  The SMTP Publisher is not supported in a fault tolerant installation of FME Flow. Consider the IMAP Publisher instead.
In this section
