FME Flow: 2025.1 BETA
Directory and Account Permissions
Directory View
Directory Required Permissions By the Account that Runs the... Notes
FME Flow install directory (<FMEFlowDir>) Write FME Flow Installer
Read/Write FME Flow Core, FME Engines, Web Application Server
FME Flow Web Application Server (<WebAppDir>) Write FME Flow Installer Applies only to a Distributed Installation of FME Flow.
/opt Write FME Flow Installer Applies only to FME Flow installed on Linux.
FME Flow System Share* Write FME Flow Installer For a Distributed Installation of FME Flow on Linux, you must create an fmeflow account before installation and assign the necessary permissions. For more information, see Provide a Remote File System for the FME Flow System Share.
Read/Write FME Engines (account should not be an administrator***)
Read/Write FME Flow Web Application Server
FME Flow Database Read/Write FME Engines Applies only to a Distributed Installation of FME Flow.
Your organization's data for running workspaces Read/Write FME Engines
FME Flow Component View
FME Flow Component Default Account that Runs this Component (Windows) Default Account that Runs this Component (Linux) Required Permissions
FME Flow Installer administrator root Write on FME Flow install directory
FME Flow Core local system fmeflow**
Read/Write on FME Flow System Share* and FME Flow install directory
FME Engines local system (should not be changed to an administrator account***) fmeflow**
Read/Write on FME Flow System Share*, FME Flow Database, and FME Flow install directory
FME Flow Web Application Server local system fmeflow**
FME Flow Database local system fmeflow**
* The FME Flow System Share files include Repositories and Resources. By default, an Express Installation of FME Flow writes these files to the path specified by the %ALLUSERSPROFILE% environment variable, which defaults to C:\ProgramData\Safe Software\FMEFlow\. If your Express Installation of FME Flow specified a different directory, or if your FME Flow is a Distributed Installation, then these files are written to the directory specified.
** On an Express installations, this account is created by the FME Flow Installer during installation. On Distributed installations, you must create this account prior to installation. For more information, see Provide a Remote File System for the FME Flow System Share.
*** To ensure the integrity of your overall file system, avoid running the FME Engines under an account with local administrator privileges, unless workspaces read or write data that requires a local installation of Esri ArcGIS. These formats require an administrator account to access the ArcGIS license.
