FME Flow: 2025.1 BETA
System Requirements
For system requirements for the Windows or Linux operating systems, see https://www.safe.com/fme/tech-specs/.
For information about supported web browsers, see Accessing the Web User Interface.
Linux: Offline Installations
FME on Linux requires many third party packages. These dependencies must be satisfied when FME is installed. The easiest way to satisfy these dependencies is to install FME on a computer that is connected to the internet, allowing packages to be downloaded as needed.
It is possible, however, to manually prepare an offline computer for FME installation.
- Get dependencies for the FME Engines component of the installation.
- Extract all files from the FME Flow installer with flags --noexec and --keep. For example:
- Get the package dependencies:
- Ubuntu/Debian: dpkg -I <package_name>.deb
- Red Hat/Rocky Linux: yum deplist <package_name>.rpm
- Get dependencies for the FME Flow component of the installation
- Packages required: zip, unzip, perl, tar, xhost, policycoreutils-python-utils
- If your deployment architecture includes the PostgreSQL database server provided with the installation (Express and certain distributed architectures), the following additional packages are required:
- Debian/Ubuntu: postgresql
- Red Hat/Rocky Linux: postgresql-server
./fme-flow-2023.0-b23277-linux-x64~ubuntu.22.04.run --noexec --keep
These flags create a folder fme-flow in the current directory that contains the contents of the FME Flow installer, including the FME Engine .deb or .rpm package.
For more information:
- Ubuntu/Debian: Installing packages without an Internet connection
- Red Hat/Rocky Linux: https://access.redhat.com/solutions/29269
Linux: Online Installations
Internet-restricted Installations through a Proxy
If installing on a machine with limited internet access in which a proxy is configured to handle communication required by the installer, the proxy must be configured to allow connections to the system package repository for that operating system.
Check for Active Subscription (Red Hat Only)
FME cannot be installed on a Red Hat instance unless it has an active subscription. For more information:
Make Sure the System is Up-to-Date
On Red Hat/Rocky Linux, run:
yum update
On Ubuntu/Debian, run:
apt update && apt upgrade
Install zip and unzip Utilities
yum install zip
yum install unzip
apt-get install zip
apt-get install unzip
Red Hat/Rocky Linux: Configure Access to EPEL Repository
On Red Hat or Rocky Linux, you must first download and install the Extra Package for Enterprise Linux (EPEL) Community Project repository.
See also:
