FME Flow: 2025.1 BETA
Installing Remote Engines Services
Use these instructions to install Remote Engines Services on a remote server. To obtain a Remote Engines Service installer, visit the FME downloads page. Remote Engines Service installers are named beginning with fme-flow-remote-engine-*.
FME Flow Remote Engines Installation Extractor
Start the FME Flow remote engines installer.
On the Installation Extractor dialog, specify a Destination folder in which to extract installation files. Note that this folder only specifies where installation files are extracted—it does not specify where FME Flow remote engines program files are installed. That location is specified later in the installer.
  • Remove these files to save disk space.
Click Install.
When extraction is complete, the installer opens. Proceed through the installer to the Destination Folder dialog.
Destination Folder
  • Install FME Flow Remote Engine to: By default, most files for your FME Flow remote engine installation are written to C:\Program Files\FMEFlowRemoteEngine\. To change the installation directory, modify the path.
  • Install the FME Flow System Share to: By default, FME Flow System Share files, which include Repositories and Resources, are written to %ALLUSERSPROFILE% \Safe Software\FME Flow\.
  • Note  Unless modified, C:\ProgramData is the default value of the %ALLUSERSPROFILE% environment variable.
    This configuration is recommended, because applications that use FME Flow to write data can access C:\ProgramData\Safe Software\FME Flow when all FME Flow System Services run under the local system account (the most common scenario), while the remaining files are protected in a read-only location. To change the installation directory of FME Flow System Share files, modify the path.
    Note  If you plan to scale-out your FME Flow anytime following installation by Adding FME Engines on a Separate Machine, the specified directory must be read/write accessible by the account that runs the additional FME Engines.
  • Install the FME Flow Database files to: By default, FME Flow Database files are written to %ALLUSERSPROFILE%\Safe Software\FME Flow\pgsql\data.
    To change the installation directory of FME Flow Database files, modify the path.
Admin User
This installation of an FME Flow Remote Engines Service creates a user to log in to the FME Flow Web User Interface. To log in to the Web User Interface for the first time as an administrator following installation, enter the User Name specified below and Password admin. You will be prompted to update the password upon initial use, based on the default Password Policy configuration.
HTTPS Configuration
To enable the Apache Tomcat web application server for HTTPS, check Enable HTTPS with certificate and provide the path to your PFX certificate and the certificate password.
Note  If you do not configure for HTTPS during installation, you can configure it later. For more information, see Configuring for HTTPS.
Web Application Server Port
Port 80 is the recommended default. If this port is in use, port 8080 is recommended. If HTTPS was configured in the previous dialog, port 443 is set by default.
Note  Common applications that may be using port 80 include Skype and Internet Information Services (IIS). Either turn off these services, or select a different port, such as 8080.
Database User
The installation creates the FME Flow Database on a PostgreSQL database server, and a user account under which to use the database. Specify a User Name (defaults to fmeflow) and Password for the database user account.
Warning  Do not specify User Name postgres. This name corresponds to the PostgreSQL master user. If the corresponding passwords do not match, the database will not install.
Note  The password for the FME Flow Database user account is encrypted in FME Flow installation files.
On the last screen, click Install.
