FME Flow: 2025.1
Before Upgrading: Things to Consider
Before upgrading FME Flow, consider the following:
  • The version of FME Flow to which you want to upgrade may have new technical requirements. For example, your current Windows server may no longer be compatible and a new server may need to be provisioned. Review the FME Platform Technical Specifications.
  • Features may be deprecated due to minimal use from users or libraries that are no longer available. Review FME Deprecations.
  • If you use Esri software with FME, it is important to review the Notes on FME and Esri Versions and Compatibility and determine if you will need to upgrade your Esri software as well.
  • Review the FME Flow product change log to see what has changed between your current version of FME Flow and the version to which you are upgrading.
  • Be aware of known issues and their workarounds.
