FME Flow: 2025.1 BETA
Before Installation
Before you install FME Flow for fault tolerance, ensure that:
  • The following components are in place on your network:
    • Separate machines on which to install the number of FME Flows that you have allocated for your fault tolerant architecture.
    • A load balancer to route traffic between each FME Flow instance you install.
    • Fault-tolerant database server on a separate machine.
    • Fault-tolerant file system on a separate machine.
  • The necessary ports are available on your network. Firewalls must permit certain ports to be opened between nodes. For more information, see FME Flow Ports.
Next Steps
Proceed to Obtain the Installer.
