FME Transformers: 2025.0
TrimbleConnectConnector
Accesses the Trimble Connect platform to upload, download, list, or delete data from a Trimble Connect account.
- Upload, download, list, or delete data from a Trimble Connect account
- Transfer data from Trimble Connect to an attribute in FME, or vice versa
- Retrieve data from a Trimble Connect account for use elsewhere in a workspace
The TrimbleConnectConnector uses your Trimble Connect account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the Trimble Connect platform.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list out Trimble Connect files; or delete items from the service. On uploads, link attributes are added to the output features. On List actions, links and file/folder information are added as attributes.
- There is a maximum length of 255 characters for folder and file names
- The upload size limit for a single file is 5GB.
- Files larger than 5MiB will be uploaded via multipart upload. Each part is 250MB.
- As described in the Trimble Connect API documentation, the upload will be marked as “EXPIRED” (and the feature rejected) if the file is not uploaded within 90 minutes for single-part upload.
- This transformer cannot be used to directly move or copy files between different Trimble Connect locations. However, multiple TrimbleConnectConnectors can be used to accomplish these tasks.
- The FeatureReader can access Trimble Connect directly (without using the TrimbleConnectConnector), however, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the action performed.
After an Upload action, the ID of the file will be saved to an attribute.
A Download action can save to a file, a folder, or an attribute.
A Delete action has no output to this port.
A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Trimble Connect Account |
Performing operations against a Trimble Connect account requires the use of OAuth2 authentication using a Web Connection. To create a Trimble Connect connection, click the 'Trimble Connect Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Region |
Either provide a valid Trimble Connect server URL or select the server region to use. Choices include:
Action |
Select the operation to perform. Choices include:
The remaining parameters available depend on the value of the Action parameter. Parameters for each Action are detailed below.
Source
Project ID |
The Trimble Connect ID of a project. |
Object ID |
The Object ID of a file or folder on Trimble Connect to delete. If valid credentials have been provided as a web connection, you may browse to a location. |
Source
Project ID |
Object ID |
The Object ID of a file or folder on Trimble Connect to download. If valid credentials have been provided as a web connection, you may browse to a location. |
Destination
Download as |
Select whether to store the downloaded data in a file, folder, or attribute.
Download to Folder |
Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder. |
Download to Attribute |
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. Note FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead.
If File Exists |
Whether to overwrite existing files in the target destination. Valid for Download as File or Folder. Default is set to Overwrite. |
Include Subfolders |
Whether to include subfolders when downloading a folder. Valid for Download as Folder. Default is Yes. |
Source
Project ID |
The ID of a Trimble Connect project. |
Folder ID |
The folder ID on Trimble Connect to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location. The folders available for listing all belong to the selected project. |
Choose whether to list contents of subfolders. Default is set to ‘Yes’. |
Source
Upload |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. If uploading a file that already exists in the destination, the existing Trimble Connect file will be updated and its version will increment. If uploading a folder that already exists in the destination, the feature will be rejected with an fme_rejection_code attribute. |
File to Upload |
The file to be uploaded to Trimble Connect if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to Trimble Connect if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
Destination
Project ID |
Folder ID |
The path on Trimble Connect to upload the source file to. To upload to the root directory, enter “/”. |
Upload with File Name |
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .dwg, .rvt, .pdf). |
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
| Dependencies | Trimble Connect account |
| Aliases | TrimbleConnector |
| History | Released FME 2023 |
Search for all results about the TrimbleConnectConnector on the FME Community.
