FME Transformers: 2025.0
SpikeRemover
Removes spikes from line, path, and area geometry.
- Data QA and cleaning
- Generalization
The SpikeRemover receives features with line, path, or area geometry and removes vertices that create angles less than or equal to a specified maximum between zero (0) and 180 degrees.
Spikes can be removed either in a single pass through the feature or iteratively, where new spikes created by spike removal are also removed until none remain.
Polygons with spikes created by their first or last points will have those spikes removed. Closed lines, however, will not. Consecutive duplicate points are also removed, whether or not they occur in a spike.
Donut polygons and aggregate geometries are supported.
Altered and unaltered geometries are output, as well as any removed vertices as points. If Remove Spikes Iteratively is No, the Removed points will receive attributes with spike angle and length.
Z values are optionally supported.
A Maximum Spike Length may be specified, and the shorter of the two sides is considered to determine overall spike length. In most cases this parameter should remain blank.
In this example, we have a polygon and want to remove a spike from it. Note there are two candidates that could be spikes.
The feature is routed into a SpikeRemover. In the parameters dialog, Maximum Spike Angle is set to 10 degrees.
The smaller of the two spikes falls under the maximum, and so its central vertex is removed. The removed vertex is output via the Removed port and receives new attributes indicating angle and length.
Note a second vertex with an angle and length of zero (0). This was a consecutive duplicate vertex, which has also been removed but does not affect the shape of the output geometry.
- The SpikeRemover is not effective when the geometry has many deviations other than spikes. Consider using a Generalizer with the Douglas-Peucker algorithm.
Features with line, path, or area geometry.
Any features modified as specified in parameters, either from spikes or consecutive duplicate vertices.
Features without spikes or consecutive duplicate points, unmodified.
Removed vertices are output here.
When Remove Spikes Iteratively is No, these attributes are added:
- _spike_angle
- _spike_length1
- _spike_length2
Features with geometry other than valid line, path, or area geometry are output via this port, as are any features that receive non-numeric values for any numeric parameters.
INVALID_PARAMETER_ANGLE
INVALID_PARAMETER_LENGTH
Maximum Spike Angle |
Specify the maximum angle in degrees between two line segments to be considered a spike. The value must be between 0 and 180 degrees. |
Maximum Spike Length |
Default: Blank. Optionally specify a maximum length in ground units. Spike length is determined by the shorter side. Spikes longer than this length will not be removed. |
Dimension |
Select which coordinates are to be used when determining spike angle and length:
Remove Spikes Iteratively |
Select a method of spike removal:
Search for all results about the SpikeRemover on the FME Community.
