FME Transformers: 2025.0
NLPClassifier
Using a trained model, this transformer classifies natural language text into different categories. It can be used for filtering, sentiment analysis, and other tasks.
NLPClassifier requires a trained *.fmd (FME MoDel) file, which are produced by the companion transformer, NLPTrainer.
- For more information about natural language processing with FME, see the documentation for the companion NLPTrainer transformer.
This port outputs each feature that was input, adding a label indicating the model’s classification of the text on that feature. This label is added as an attribute with the specified attribute name. If the text was not read from the feature, the text will also be added as an attribute with the name ‘__nlp_text’.
Features for which the model cannot classify the text, often because the text itself cannot be retrieved, are routed to this port.
Classifier Model |
The location of the *.fmd file to use as a model for classification. |
Text to Classify |
The text to classify from each feature. |
Label Attribute |
The attribute name to use when adding labels to features with classified text. |
| Dependencies | |
| Aliases | NaturalLanguageProcessingClassifier |
| History | Released FME 2019.0 |
Search for all results about the NLPClassifier on the FME Community.
