FME Transformers: 2025.0
FMEFunctionCaller
Calls a specified FME function, optionally storing the resulting value in an attribute.
- In rare cases, calling a specific FME function.
The FMEFunctionCaller may be inserted anywhere in a workspace, and runs individual FME functions. It is a legacy transformer that exists for backward compatibility, and should rarely (if ever) be used.
It may not support newer FME functions. Functions that are not supported will produce an error message indicating that the function is not recognized.
Information about FME functions may be found in the FME Factories and Functions documentation page - as noted above, not all functions will be supported in this transformer.
You may provide an attribute name to store the result in, and specify a configuration line for those functions that require one.
The @Reformat function requires a configuration line. To employ it within a workspace, the function would be called like this:
The configuration line which defines the "BinaryKey" binary structure is specified in the Configuration Line parameter.
This transformer accepts any input features.
Features with the results of any functions called applied.
FME Function |
Specifies the FME function (@FunctionName) to be called, as well as any parameters it can take. |
Configuration Line |
Optional: Can be specified if the underlying FME function requires it. |
Recursive Evaluation |
Evaluate the FME Function recursively. If the result of the function or any of its parameters is another function, evaluate that as well. Keep this disabled for fastest performance. |
Result Attribute |
(Optional) Name the attribute to contain the value returned by the FME function. |
Search for all results about the FMEFunctionCaller on the FME Community.
