FME Transformers: 2025.0
DocumentPDFStyler
Prepares features for output to the PDF Writer by providing a convenient interface to set a variety of PDF format-specific attributes.
For more information regarding PDF styling, see the PDF Writer chapter in the FME Readers and Writers help. (In FME Workbench, select Help > FME Readers and Writers.)
When creating a workspace with multiple stylers, it is important to set Transformer flow. See Controlling Transformer Flow at Runtime.
Content Type |
This parameter specifies what kind of PDF content this feature will add into a document. Based on this parameter the rest of the parameter dialog will change. Format attribute set: documentpdf_type |
Available Styling parameters vary according to Content Type selection.
Font |
Specifies the typeface, size and emphasis (Bold, Italic, Underline, Strikeout) used for the text. If a font cannot be found on the system, DocumentPDF will fallback to Helvetica. Format attributes set: documentpdf_font_family_[suffix] documentpdf_font_size_[suffix] documentpdf_font_emphasis_[suffix] |
Font Size |
Specifies the size of the text in points. Format attribute set: documentpdf_font_size_[suffix] |
Font Color |
The color of the text foreground. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). If the value type is unclear, the 24-bit interpretation is used. Hex codes are accepted with or without a hash sign (#).
Format attribute set: documentpdf_font_color_[suffix] |
Background Color |
The color of the text background. Specifying Colors Colors may be entered directly or chosen from the color picker via the ellipsis button. Colors can be specified by RGB values or hex codes. RGB values may be either 24-bit or decimal (0 - 1). If the value type is unclear, the 24-bit interpretation is used. Hex codes are accepted with or without a hash sign (#).
Format attribute set: documentpdf_background_color_[suffix] |
Opacity |
Specifies the opacity of the element as a number from 0 to 1. 0 is completely transparent, 1 is fully opaque. Note: Only enabled for watermarks. Format attribute set: documentpdf_opacity_watermark |
Alignment |
Specifies the alignment of the element:
Format attribute set: documentpdf_align_[suffix] |
Line Spacing |
Defines the spacing between lines of text. Multiplier. 1 has no effect. Format attribute set: documentpdf_line_spacing_[suffix] |
Top Padding |
The amount of padding at the top of the element in points. Format attribute set: documentpdf_padding_top_[suffix] |
Bottom Padding |
The amount of padding at the bottom of the element in points. Format attribute set: documentpdf_padding_bottom_[suffix] |
Left Padding |
The amount of padding at the left of the element in points. Format attribute set: documentpdf_padding_left_[suffix] |
Right Padding |
The amount of padding at the right of the element in points. Format attribute set: documentpdf_padding_right_[suffix] |
Border Layout |
Specify which lines of the table are visible:
Outer Border Width |
Width in points of the outer border. |
Heading Level |
Headings have different levels. Example: Heading 3 is a subheading of Heading 2, and if you collapse a heading of heading level 2, the entire document under it until the next heading level 2 or heading level 1 will be hidden, even if there are headings of level 3 or greater among the hidden text. Format attribute set: documentpdf_heading_level |
Text |
This parameter controls what text the heading will show Format attribute set: documentpdf_text |
Image Filename |
Specify the path and filename of the image. Format attribute set: documentpdf_image_filename |
Image Width |
This in conjunction with Width Units specifies how large to scale the image. If Percentage of Page Width was chosen for Width Units, then 100 means the entire page width, while 1 means only one percent. Format attribute set: documentpdf_image_width |
Width Unit |
This in conjunction with Image Width specifies how large to scale the image. If Image Width is not empty, Image Width specifies the unit of the Image Width value. If Percentage of Page Width is chosen, then it means the percent of page within the left and right margins. Format attribute set: documentpdf_image_width_unit |
Caption |
Specifies the image caption. Format attribute set: documentpdf_text |
Caption Position |
If Caption is not empty, Caption Position specifies the position of the caption, Top or Bottom. Format attribute set: documentpdf_image_caption_position |
Link Type |
Specifies the type of link for the image.
Format attribute set: documentpdf_image_link |
Ordering |
A list can either be Ordered or Unordered. An ordered list is prefixed with a number, and an unordered list with a black dot. Format attribute set: documentpdf_list_item_order |
Indent Level |
How much indent to place left of the list item. If the list is an ordered list, and the indent level changes, then the list item counter will reset to 1. Format attribute set: documentpdf_list_item_indent_level |
Text |
This parameter controls what text the list will show. Format attribute set: documentpdf_text |
Page Break inserts a page break and has no parameters.
Page Orientation |
Specify the orientation of all following pages.
Format attribute set: documentpdf_page_orientation |
Page Size |
Specify the page size of all following pages.
If Custom, specify a Page Width, Page Height, and Page Size Unit. Format attribute set: documentpdf_page_size |
Page Width |
If Page Size is Custom, this parameter in conjunction with Page Size Unit specifies a custom width for all following pages. |
Page Height |
If Page Size is Custom, this parameter in conjunction with Page Size Unit specifies a custom height of all following pages. |
Page Size Unit |
If Page Size is Custom, this parameter in conjunction with Page Width and Page Height specifies a custom size for all following pages. Format attribute set: documentpdf_page_size_unit |
Header |
The header text to insert at that alignment. Format attribute set: documentpdf_header_[left|center|right] |
Footer |
The footer text to insert at that alignment. Format attribute set: documentpdf_footer_[left|center|right] |
Watermark |
Specify text to appear diagonally across the page. Format attribute set: documentpdf_watermark_text |
Text |
The text of the paragraph. Format attribute set: documentpdf_text |
The Table of Contents is generated from headings and has no additional parameters.
Column Header |
The heading text for the particular column. Format attribute set: documentpdf_table_row_headings |
Column Value |
The text value to place in a row under the particular column. Format attribute set: documentpdf_table_row_values |
Column Width |
Any positive number in [0, 100], or the word Stretch. Columns with the width Stretch will all share any leftover space after columns with specified sizes are given their space. If a numeric value was chosen, then 100 means the entire effective page width, while 1 means one percent. Format attribute set: documentpdf_table_row_widths |
Text |
This parameter controls what text the title will show Format attribute set: documentpdf_text |
Search for all results about the DocumentPDFStyler on the FME Community.
