FME Transformers: 2025.0
AzureServiceBusConnector
Connects to Microsoft Azure Service Bus.
Receive and send messages from a queue or topic
- Interoperability with Big Data analytics platforms
The AzureServiceBusConnector connects to Microsoft Azure Service Bus. It supports sending and receiving messages with Queues and Topics.
More information about Service Bus can be found in the official Microsoft documentation.
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
After a Receive from Queue action, output features represent messages received from an Azure Service Bus Queue.
After a Receive from Subscription action, output features represent messages received from an Azure Service Bus Subscription.
On a Receive from Queue or Receive from Subscription action, heartbeat features will be output through this port. Heartbeat features will have two output attributes:
- _heartbeat_id: Integer starting at 0. This is a unique identifier for each heartbeat feature output from this port.
- _heartbeat_counter: Integer starting at 0 that resets whenever the connector receives a new message and a new period of inactivity begins. This counter represents the number of consecutive heartbeat features.
See Heartbeat for more details.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Credential Source |
Required for authentication. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when Credential Source is Web Connection. To create an Azure Service Bus connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Namespace |
Available when Credential Source is Default Azure Credential. This is the Service Bus Namespace containing Queues or Topics. The value is typically a hostname under servicebus.windows.net. |
Embedded Credentials
Service Bus Connection String |
Available when Credential Source is Embedded. The connection string is found in the Azure Portal Service Bus Namespace under Shared Access Policies. |
Action |
The type of operation to perform. Choices are:
Event Hubs |
The event hub to connect to. |
Count Messages Options
Resource |
The resource to count available messages. Either Queue or Subscription. |
Receive Options
Receive Mode |
Two message receiving options are available:
Delete on Receive |
If Yes, deletes the message from the queue upon receiving. If No, the message is retrieved but stays in the queue. The message will be available to receive after the lockout period. |
Batch Size |
In Batch mode, specifies the number of messages to read per batch. Default is 1. |
Heartbeat
When Action is set to Receive from Queue, a heartbeat feature is output through the Heartbeat port after a period of inactivity. The length of this period is determined by the following parameters:
Interval |
The period of inactivity before a heartbeat feature is emitted, in units specified by the Time Unit parameter. Defaults to 1. |
Time Unit |
The unit for Interval.
Defaults to Hours. |
Receive Options
Receive Mode |
Delete on Receive |
If Yes, deletes the message from the subscription upon receiving. If No, the message is retrieved but stays in the subscription. The message will be available to receive after the lockout period. |
Batch Size |
Heartbeat
When Action is set to Receive from Subscription, a heartbeat feature is output through the Heartbeat port after a period of inactivity. The length of this period is determined by the following parameters:
Interval |
Time Unit |
Send Options
Queue |
The Queue to send messages to. |
Create Queue |
If Yes, create the queue with the given name. A message will be logged if the queue already exists. If No, use the available queue. |
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Message Properties |
Custom settable message properties. Any key value can be used, however the following keys are mapped to the respective attributes on the message.
Send Options
Topic |
The Topic to send messages to. |
Create Topic |
If Yes, create the topic with the given name. A message will be logged if the queue already exists. If No, use the available topic . |
Payload |
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
| Dependencies | Microsoft Azure Account with the Service Bus Service |
| History | Released FME 2019.2 |
Search for all results about the AzureServiceBusConnector on the FME Community.
