FME Transformers: 2025.0
AnchoredSnapper
Brings lines, segments, end points or vertex points of features together if they are within a certain distance of each other, where one set of features is non-moving.
The difference between the AnchoredSnapper and the Snapper is that anchor features are considered to be accurate and consequently do not move.
- Any feature that undergoes dimensional collapse as a result of being snapped will be output through the Collapsed port.
- A short cleanup step is performed after snapping. This step will remove duplicate points, and may create aggregates to preserve overlapping, directed segments.
- Features with geographic coordinates (latitude/longitude) will likely need to be reprojected to a coordinate system with real-world ground units (such as meters) to match the Snapping Distance parameter value.
Features that may have Candidate features snapped to them. Arcs are snapped as linear features, and ellipses are snapped as polygonal features.
Features that may be snapped to Anchor features. Arcs are snapped as linear features, and ellipses are snapped as polygonal features.
Candidates whose geometry is changed by the transformer.
Candidates that leave the transformer without being changed.
- If a line or area feature snaps down to a single location, it will be output as a Point geometry, through the Collapsed port.
- If an Aggregate, MultiArea, or MultiCurve geometry has any parts snap down to a single location, a Point geometry for each part will be bundled up into a MultiPoint geometry and output through the Collapsed port. The remaining parts which did not snap down to a single location (if any) will be output as a group through the Snapped port.
The anchors that were used during snapping. If a candidate was snapped to a point along the segment of an anchor, a new node is inserted into the anchor’s geometry.
Features whose geometry is unsnappable (for example, having a non-finite coordinate) will be rejected and output via this port.
Rejected features will receive an explanatory fme_rejection_code attribute.
Group By |
If Group By attributes are selected, features are only snapped to other features with the same values in the group by attributes. |
Complete Groups |
Snapping Type |
When Snapping Type is End Point Snapping:
When Snapping Type is Vertex Snapping:
When this parameter is set to Segment Snapping:
Snapping Distance |
Snapping Distance specifies the distance, in ground units, that the snapping occurs between features. |
Tolerance |
When Snapping Type is Segment Snapping, this transformer performs data cleaning that is meant to improve the robustness of the results when they are used in other algorithms by ensuring that no two vertices in the snapped output are within tolerance of each other. If Tolerance is set to Automatic, a tolerance will automatically be calculated for the cleaning operation, based on the size of the inputs. Otherwise, a custom tolerance may be used. |
Add Additional Vertex |
This parameter applies only when the end point of a feature is being snapped.
Yes |
| Aliases | FixedSnapper BaseSnapper |
Search for all results about the AnchoredSnapper on the FME Community.
